- Facility
- ZSE Seattle Center
ZSE is currently at 6 possible releases, all Category 2
Thanks
No, they cannot.If I was selected on the last ERR, have signed my FOL, have a date established, can Management push my date back if someone straight up quits?
No that list is a frozen priority from around the first of the monthDoes the list under "latest resources" take into consideration facility pick ups from the previous experience hire?
YesWould the flight service people then go to the Academy?
It's unfortunate that it generated additional academy slots. The issue that you described has been around for awhile. I'm assuming you're talking about the double counting of some Outbounds/Inbounds? It "resolves" itself by removing the 'placement list' inbounds/outbounds on the 2nd PPT following a panel, but as you mentioned, if additional academy slots are being created in the interim, that will create a large ripple effect.PSA for those of you at 7s and below that need inbounds for your projected: I noticed some discrepancies in regards to Dec NCEPT Outbounds on the Jan PPT and brought it to the attention of my ATM and RVP but nothing came of it. The discrepancies I noticed were for like type facilities and I wasn't surprised that it didn't seem to generate serious concern because on the surface it can appear insignificant nationally but it can be extremely significant locally. Extra Outbounds can potentially be disasterous if not corrected before the NCEPT but conversely can be benificial, to a facility that receives new hires, if not corrected between NCEPTs. So in this case a certain facility generated multiple (7 or so) high priority academy slots (2 of which were mandatory) for the Terminal class that graduated today because of 3 fake Outbounds entered in the SWB. The biggest problem with this is these lists are Zero-Sum so every extra slot mistakenly assigned is a slot stolen from another facility. To aggravate things further this is the only Terminal class to graduate before they freeze the PPT on Jan 24 for the Feb NCEPT. Next class is 1/26.
Just more things to look out for.
Yes that's correct. But only some facilities' Outbounds are placed into both categories. Some facilities were impossible to cross reference but I couldn't find a trend by district or region or TOL. And if there's multiple people counted twice at a place with a lower target then it creates a massive make believe percentage swing.It's unfortunate that it generated additional academy slots. The issue that you described has been around for awhile. I'm assuming you're talking about the double counting of some Outbounds/Inbounds? It "resolves" itself by removing the 'placement list' inbounds/outbounds on the 2nd PPT following a panel, but as you mentioned, if additional academy slots are being created in the interim, that will create a large ripple effect.
FSS will now be included in the NCEPT process. If you know of anyone currently in FSS trying to transition over to ATC, get the word out ASAP. This is huge for them and with bids for FSS showing up on USAJobs, the backdoor into the agency has returned."
NCEPT - NCEPT MinutesLvl 7 washout here. I washed in the tower at a 7 up/down, so I don't have a CTO or any real quals. Now, I'm in Alaska training in FSS. It's not all that bad, but I'd like to get some insight into the possibility of ERR'ing from here to a low-level tower. I couldn't find the minutes online, and no one at my facility knows much about the process of leaving AK FSS and going to a tower or center. Couple of questions..
1) Did they mention FSS Nest employees (washouts like me who got sent to Alaska)?
2) As a non-CPC FSS employee, should I wait until I CPC to try to ERR?
3) Should I even bother putting in paperwork to anything except for Lvl 4 or 5 towers?
Every tidbit of info helps. Thanks!
FSS to ZNY all day every day.Cant wait till FSS start getting picked up at lvl12s
What's special about a situation that hasn't happened yet? The amount of time a person takes to respond to a TOL is irrelevant. It doesn't change release dates. If you can't accept a TOL from a facility you have an ERR to, remove it.Can anyone tell me how long you usually have to decline a TOL? Would anyone happen to have the date that someone picked up on the Feb 2018 panel would have to accept or decline their TOL by? Dealing with a bit of special situation here.
